주요 콘텐츠로 건너뛰기
시대의 변화에 따라 USB to Lightning 케이블에서 USB 단자만 USB-C 단자로 변경된 Apple 정품 케이블.
How do I know which wires connect to which?
My dog chewed through my USB-C to USB-C cable that came with my 2020 MacBook Air. I’ve tried to connect all the wires by matching their colours but I’ve plugged it in and it still doesn’t work. Since there are three red wires I wondered if the order they are reconnected in matters. I am an amateur and don’t really know what I’m doing so any advice would help out.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sorry, you really need a new cabled here.
Did you ever see a Cray micro computer? All the wires are White! The cable vendor doesn’t need to follow reason. And you can’t assume Red #1 is equal to function to Red 2# line.
The other factor here is besides power there are data lines and the construction of the cable is likewise important for signal integrity.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Do you think if instead of joining the two parts, I should stop the wires on one end and solder it to the other? Would that be a better alternative?
@jesuskhan - OK, this is how I would do it. I would use an Ohm meter and measure one line and the connectors contacts to isolate the active pin. Repeat for the other side. Doing each wire one at a time. And you still need to re-join the shield connection as it’s electrically active as well.
Really a lot of work to band-aid a cord which won’t last very long and could create a safety issue. I would replace the cord it’s not worth the effort.
댓글 달기
답변을 추가하세요
Jesus Khan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 8
전체 시간: 239
