Laptop went off and can't switch it on. the board is getting hot
좋은 질문 입니까?
좋은 질문 입니까?
A hot board is a sign of high current draw. You need to ID the hot part. It could be part of the CPU power supply. That might indicate a bad CPU. If the CPU is hot, that would also indicate a bad CPU. OR the CPU PSU is putting out to much voltag to the CPU.
해당 답변은 도움이 되었습니까?
@keithmazyopa start disassembling our laptop and let's see what you got going on here. Use something like this video to work on it. Once you have it disassembled, take some good pictures of the board. Then post those with your Question. It will allow us to see what you see. Also, verify that it is the board that gets hot and not the battery. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 86
Hi, Do your fans come on when you try to power on the laptop?
James 의
thank you , but this one it has no fans
Keith Mazyopa 의
I'd like to know if there was water damage done to the laptop, if not i think you should try booting it into recovery mode
CheckM@te 의
@keithmazyopa Is it a Chromebook?
James 의
