주요 콘텐츠로 건너뛰기
Apple이 설계한 M2 Pro 및 M2 Max SoC를 탑재하고 올해 1월 출시된 14-인치 MacBook Pro의 수리 안내서 및 분해 정보입니다.
Will Not Turn on but will Chime
My Macbook suddenly quit. I've tried the fixes on the Apple site, but it's not clear what works for the M-series chips and what works for Intel chips.
The machine will chime. I can wait a few minutes and press a key, and it will chime again. Sometimes the chime is cut short by a staticy noise.
I think the GPU died, as I was having screen freezes during a Zoom call earlier in the day.
For the M-series Macs, I found guidance that said to hold the power button for ten seconds, wait, and repeat until it boots up.
I appreciate any advice!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Compared to some of the other answers on here, this probably sounds stupid, but have you tried an external monitor?
@fixer85785 - Not a bad idea! But lack keyboard backlight aims to a logic board power issue within the backlight logic. That of course is based on the new info Chris gave us.
댓글 달기
답변 3개
That sounds Iike a BIOS beep, possibly (which does indeed usually mean something is broken or disconnected)
^ignore this part
Based on my understanding of modern Mac(s), the GPU can’t suddenly “die” on its own, since the GPU (and most of the other components) are actually just one large chip (System on [a] Chip). While the GPU segment may be toast, you can’t really replace just the GPU, and would have to replace the entire SoC (if not the entire board).
Also, is there only a single chime? Does it repeat? Does the screen backlight turn on?
(Sorry about the unhelpful answer, I’m sure one of the Mac users will write a few paragraphs featuring detailed boardviews, schematics, and troubleshooting steps.)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
A single chime (bong) is normal. A EFI (Mac’s don’t technically don’t have a BIOS) error would be a 3 long then 3 short beep code, but that was with the Intel CPU based systems.
It's one startup chime, and that's it. No backlight and no keyboard lights.
댓글 달기
The M series SoC’s don’t have independent CPU and GPU chips like some of the older MacBook systems have.
Sadly it does sound like a deeper logic board issue.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
And since everything's on the board, there isn't a way to save the hard drive data unless I find someone with mad soldering skills?
@cs_harris - Sadly that tends to be the case. You might be able to connect a second Mac to your system then using Target Disk Mode gain access to your drive via the other Mac Transfer files between two Mac computers using target disk mode
댓글 달기
I would recommend trying DFU revive using another MacBook.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christopher Sean Harris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 35
전체 시간: 246
