주요 콘텐츠로 건너뛰기
2022년 Apple의 최고급 플래그십. 9월 16일에 출시된 iPhone 14 Pro Max는 6.7형 ProMotion OLED, 새로운 Bionic A16 칩, 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 13 Pro Max의 후속 제품입니다.
iPhone 14 Pro Max restarts randomly after screen repair
Just randomly restarts every 5 or so minutes. I checked the battery connector and display connector. I did rip the front assembly connector, but I was told it would be fine without it. Just the proximity sensor wouldn’t work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Hi Travis,
On the iPhone 14 the proximity flex cable will cause a kernel panic if the sensor on it cannot be read, which is exactly what's happening with your reboots. If you actually time the reboots, you'll find they're happening every three minutes, which is the interval in which the phone checks its sensors.
You can read all about it on the iPhone Kernel Panics wiki page here.
iPhone Kernel Panics - iFixit
The upshot is your information about the torn proximity flex cable was incorrect; your phone is going to reboot itself every three minutes from now to eternity until you replace that part. Here's what you need.
iPhone 14 Pro Max Proximity Light Sensor Replacement – Repairs Universe
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Does the sensor need to be paired with phone or can the part just be installed and would work?
@michaelweezie No, there are no pairing issues with the proximity sensor, so installing it is all you should have to do.
댓글 달기
While replacing my screen the proximity light sensor ribbon cable broke. Thinking not a big deal I’ll just have a feature I can’t use. My phone would turn on work for a few minutes then freeze, give the pink screen of death and reboot. This article helped me understand what was going on and the linked replacement part was reasonably priced and arrived quickly. Thankfully the new part resolved my issue as the stores near me said the only fix was an entirely new phone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Travis Cunningham 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 28
지난 30일: 156
전체 시간: 3,252
