gear shifting not smooth got stuck every time I change gear
Problem in shifting gears
좋은 질문 입니까?
점수
0
좋은 질문 입니까?
Assuming your vehicle has a hydraulic clutch system then your problem sounds like it is most likely either low of fluid, out of adjustment due to normal wear, broken or collapsed line from the clutch master cylinder to the slave cylinder, or one or both of the before mentioned cylinders has gone bad.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 9
30일 전: 75
전체 시간: 278
