주요 콘텐츠로 건너뛰기
G4 Quicksilver는 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, 그리고 1.0GHz 속도로 출시되었습니다.
49 질문 전체 보기
Upgraded 800Ghz G4 to a Dual 1Ghz G4 Processor with Kernal Panic?
I removed the 800Ghz G4 Processor then Replaced upgraded to Dual 1Ghz G4 Processor.
The system started with the Apple Chime and OSX 10.5.6 but then I received a kernel panic screen with errors.
Is this a OSX software nightmare?
Does the Operating System think it is trying to boot to a Single Processor? and gets confused about the Dual Processor? or was I supposed to change some settings via the sautering? scheme I have seen?
Please help....
I get White Buttons and the system just runs quiet.......
How do I get it to REINSTALL the OSX CD?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
가장 유용한 답변
I would wipe it out and restore. But on a side note, did you reapply thermal grease for the new CPU?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
no I did not.....is that needed? I didn't see any grease on either processor...but I would like to follow your process as I have heard that too on other system builds.......I didn't see it on this one.
I can find it at Fry's I am sure....
but can you please please tell me how to wipe it out and restore...
if the computer is not responsive....I mean I should have placed the CD in the Drive when I had the APPLE showing before the KERNAL PANIC.....
Now all I get is White Button and FAN noise.......
So I am unsure how to get back to the process of making the computer first OPEN The CD DOOR so I can PUT a CD INTO IT.....and then allowing it....
The keyboard seems unresponsive....so does the mouse....
Before it was in the programmers setting at Kernal Panic but Frozen....
So I shut down by pressing the power button.
Now when I repress the inside button for 30 secs........after unplug ofcourse....
I was going to try to RESET PRAM by holding the keys PRAM but again....I was not getting any response just the system turns on......
What should I do next to reinstall the OSX software?
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Sorry about the late reply... I've been busy with school. Thermal grease is a MUST. It helps the heat dissipate from the CPU to the heatsink, without it you're going to overheat and possibly damage your computer. Getting it semi-responsive will have to be the first step.
댓글 달기
Well I need to get the grease and re apply it and
What do I do if it is just giving me the white buttons?
Nothing?
I had another Mac do this to me too
I dunno what to do at this point
Instead of putting the old processor back
Do you in fact know if there is a problem with switching out a single processor to a DUo processor type configuration
The OSX was expecting the setup from the last restart
But I pushed the button inside the thing
Unplugged and many 30sec pauses
Holding the button
Even waiting a few days
Not powering this thing up again until I heard from you and had the grease on the CPU or tried replacing the other CPU to see if that was the issue
I really need the dual processor to work
I didn't leave the unit on very long when I tested it
As soon as the kernel panic happens I shut down but then I get that white button upon trying to start up again
What next?
Do I need clean harddrive in there? No OSX
How do I get it to respond to CDRom install?
If I just get white button and then nothing ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem and I checked the model and the processor was incompatible. Check the model and see if a dual GHz cpu is supported.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Singleton Makin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 441
