주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lens cover won’t stay in place
My Eufy video doorbell is c 3 yrs old.
I recently noticed there was water under the glass disc which covers the camera lens and brought the device indoors to try and dry it out.
The lens cover subsequently fell off and will not stay back in place.
On inspection, it seems the “bezel” which retains this glass disc, and keeps things waterproof, has degraded.
The company can’t give me any advice re repair and just tell me to buy a new unit.
I feel this is wasteful - and surely the design life of this sort of tech should be longer than 3 years!
Can anyone suggest a safe way I could secure the glass cover back in position?
The only thing I’ve though of is tracing a bit of glue round the perimeter with a cocktail stick and then pushing the lens cover back in position.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I had exactly the same problem and added some kit (TEC7) between the protective plastic circle (it is not really a lens) and the enclosure. Make sure the lens is dry and don't push to hard when closing it. I used 2K glue before that, but that didn't keep it watertight. The TEC7 kit (some kind of silicone kit) worked better.
But then the microphone died after a while and I can't get that repaired...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Mon disque s'est détaché, j'ai mis de la glu en gel, mais il y a un nuage sur la lentille comme si la glu avait déposé un film ???
Je vais essayer de démonter par l'arrière et regarder si je sais essuyer avec un coton-tige.
Si je dois remplacer le matériel, j'achèterai certainement une sonnette Tapo de TP Link, j'ai plusieurs camera c310 et c320 qui sont à la pluie battante depuis 2 ans sans soucis. Ma lentille s'est juste détachée 1 mois après la fin de la garantie.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Betty Mack 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 64
전체 시간: 1,585
