주요 콘텐츠로 건너뛰기
Repair guides and support for the C650 series of Satellite laptops by Toshiba.
33 질문 전체 보기
Why my PC has ceased recognizing any flash drives plug in
The problem is that the PC has ceased recognizing any flash drives plugged in, and I am not sure why. Could there be any wiring issue involved, and is there something that could be done about it
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Good afternoon,
I'm assuming as this is a toshiba. That you are using a windows operating system, if you are on the off chance on Linux please let me know.
Dependant on the operating system there are a few ways to diagnose this issue.
I'd like you first to start by removing the flash drive and then press the "windows" key on your keyboard and type In disk management
Once this page is loaded, keep track of how many disks are listed (starting with disk 0)
With the page loaded plug back in the flash drive, do you see any new disks listed?
If so what do you see? If these disks previously had no data on them(or data you aren't afraid to lose) and the newly added disk states "waiting Inialization" go ahead and initialize it, you should then be able to use that flash drive like new.
I will eagerly wait your respond to continue assisting you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Meklit Seboka 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 36
