주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Asus Republic of Gamers laptops.
352 질문 전체 보기
My asus laptop won't power on.. when put on charge, it indicates its c
My asus laptop won't power on.. when put on charge, it indicates its charging but won't but when I power it on it won't come on.
What can be the possible solution?
Ram dead?
CMOS battery dead?
ASUS ROG G551JM
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @redeemgrimm
Try a power reset and check if that resolves the problem.
Disconnect the charger and then remove the battery from the laptop.
Then press and hold the power button for 30 seconds and then release it.
Reinsert the battery and connect the charger and check.
If still no good it may be the RTC coin cell battery (aka cmos battery). The problem with this is that this battery is located on the underside of the motherboard. (click on 2nd smaller image on left side of main image to see the CR2032 battery lower left side of board in image)
To access it you will have nearly completely disassemble the laptop. Once you have removed it from the board, measure its voltage. If it is <2.4V DC or is >5 years old, replace it. These batteries are commonly available everywhere e.g. supermarkets.
By the time you have accessed, removed/replaced the RTC battery and reassembled the laptop, the BIOS would have been reset so once the laptop is completely reassembled, connect the charger and check if it turns on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Redeem Grimm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 29
