주요 콘텐츠로 건너뛰기
닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
706 질문 전체 보기
There is no place to screw in screws for the right joycon sensor rail.
A car door got shut on the docked, right joycon of my nintendo switch ripping out the sensor rail with it. I've replaced the joycon, and am on to replacing the sensor rail, when I was screwing it in, I realize that there is nowhere to screw it into. Can I glue it in? What part do I need to replace to fix this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I ran into the same situation when my granddaughter somehow managed to rip one of her joycon controllers off the Switch, leaving it in the same situation you're in, with nowhere to screw in the rail.
I looked at several different possible solutions initially, but finally ended up biting the bullet and replacing the midframe. The midframe is what the joycon rails screw into, so when they're broken out the pot metal the midframe is made of tends to come apart. Here's the guide I ended up writing as a result of that adventure.
Nintendo Switch Midframe Replacement - iFixit Repair Guide
The other repairs I considered included things like filling the broken metal with JB Weld epoxy then drilling and tapping new holes, buying longer screws with nuts to be mounted behind the original screw mount, or just epoxying the screws in permanently.
To be honest, there isn't really a good solution here; the one I picked means you have to completely gut the entire Switch and move every single component to a new midframe. However, the other choices just didn't strike me as much better in terms of being a long-term permanent solution that was going to stand up to my rather breakage-prone granddaughter.
That's what I ended up doing; if you decide on another solution I'd love to hear about it; take pictures and maybe make your own guide to that repair; I would sure love to have had a better choice available. Let us know how it all turns out!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Lunearity 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 24
