주요 콘텐츠로 건너뛰기
A range of older (and newer) premium coffee makers from Jura.
Water in and on drip tray
I am trying to repair a (1st gen) Jura Z5 Impressa coffee machine and I hope anyone can help. I've found the online repair guides which have been very helpful but I'm unable to find a fix for my problem. So far I've taken apart the brew group and replaced the rings; I replaced the entire drainage valve. I've also cleaned and partially replaced the outlet valves and decalcified and cleaned the machine using tablets. The machine works and the coffee is fine but I feel that there's a lot of (brown) water in and on the drip tray. Also, I noticed that during decalcifying, no water came out of the outlet but it did make a sound. Does anyone have any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The Z- Impressas are rather sophisticated... Brown water = coffee?! Hmmm. Try using the device without sidepanels (Caution!) or the frontpanel of the drip tray and look, if you can see where it comes from. My first idea is that you should also check the solenoid for the drain valve, if its piston moves freely. This guide helps. My second idea is the ceramic valve.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks, I really appreciate it. Now I know what else I can try.
댓글 달기
답변을 추가하세요
JuraZ5 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 21
전체 시간: 364
