주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why only two LEDs on my computer are lighted
이미지
이미지
이미지
I acciently pluged 220V, and the power supply bombed... and I replaced it with a good-working one. But only LED1 and LED2 are lighted, fans aren't worked, and only harddisk is still working. I tried three different RAMs and I'm sure Ram is OK. What's the problem???
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 10개
@highsheep have you had a chance to look at the logic board yet? Time to tear it apart and check for damage. There are plenty of capacitors that will take a hit on the 220V. Might be time to recap the beast anyway. We really need to see this board to assist you with that. Luckily schematics and board views should be available, we just need to know what your exact board number is. I suspect a 820-1540 All you have to bring to the table are the soldering skills and obtaining components :-)
Once you have your board removed. Take some good pictures (top and bottom) and post those with your Question. That way we can see what you see. 기존 질문에 이미지 추가하기
@oldturkey03 I put my pictures below
@highsheep I guess it turned out to be a 1540 and they promptly place a sticker over it :-)
@highsheep you will need this for sure. LB# 820 1540 Start with the power block diagram and see if you get a feeling for it. Then take a look at all of the power rails (focus on page 7) Inductors and voltage regulator love to get destroyed in overvoltage situations. Anyhow, you will have to be okay with reading schematics, and basic testing of components. We can always assist but you are the hands, eyes and ears of this operation ;-)
@oldturkey03 Thanks, I'll have a try
댓글 5개 더보기
댓글 달기
답변 1개
선택된 해법
Ouch! Sounds like the logic board got hit as well.
Not much you can do here, either replacing the logic board or if you have the skills fixing the damaged circuits within it.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Acutally I want to fix it by myself, I really enjoy the process. Can you give me some tips about it?
@highsheep - you’ll need to surf the web to find the schematics and board drawings so you can ID the components and the voltages of the power rails to help narrow down things.
If you look at the logic board you should find it’s number it typically starts off as 820-???? Use that to search by.
@danj Thank s fir your help
댓글 달기
답변을 추가하세요
Highsheep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 34
전체 시간: 384
