주요 콘텐츠로 건너뛰기
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
Anti theft system/Lock system, stuck in learning mode
So I got an 05 grand prix, the theft system is in learning mode and I can start it, though I only have the valet key for it, I assume if.i just do the learning procedure it will take it out of learning mode though, I haven't tried it cause I'm not sure if my key will start it if I do and I'm not ready to pay for that headache , unless itl be fine if I do take.it out of learning mode, also having issues with the door lock switches only locking the doors and the trunk release won't work either cause it's part of the lock switch, but putting it into drive locks and putting it into park unlocks them just fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If you do take it out of learning mode and your keys can’t start it use this method
*****THIS IS A COPY*****
Put the key in the ignition and attempt to start the car, the "Security" light should go on and the car won't crank. Don't move the key to the "off", leave it on.
  1. Leave the key in the on position for around 10 minutes, the security light should eventually go out.
  2. Turn the key to "off", wait 5 seconds, then attempt to start the car. If it starts, you're done! If it doesn't start, to back to step 1 and try again. You may need to repeat this process up to 3 more times to get the car started.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I don't know how to get it out of learning mode though.
The security light never goes out I waited for a full 30mins even
@jameswiencek I don’t know then I’m sorry
댓글 달기
답변을 추가하세요
James Wiencek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 26
전체 시간: 670
