주요 콘텐츠로 건너뛰기
A series of 15.4" Toshiba laptop in the Satellite line.
Distorted Audio in laptop speakers and headphones
The Audio on my Toshiba Satellite Pro is frequently distorted in applications like spotify and itunes and on the web. it happens with any audio that is being played. majority of the time it's fine however it goes distorted occasionally is this a driver problem or a hardware problem? (I am running Windows XP Home Edition SP3)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Not having much detail and assuming both channels are distorting, I can venture the following:
Audio distortion can be due to a number of factors
  1. Turning up the volume to a point where the load (speakers/headphones) can't handle the power can cause AF clipping (distortion).
  2. The built-in amp is being overdriven IOW not enough power to handle the volume
  3. The built-in laptop audio amplifier has a component (such as a Capacitor for example) that is intermittent and will cause distortion under certain conditions (overdriving, overheating, Age)
  4. So, this sounds more like a HW problem. I am assuming the laptop is a number of years old and was acquired when XP was still the go-to opsys
  5. A common way to test (if you are able to get at the laptop's innards) is to induce or wait until distortion occurs and then apply a freeze-it spray to where you suspect the AF amp and components to be. This most likely will be an IC but with larger output capacitors usually mounted as discreet components on the pc-board itself. If the distortion dissapear you may have fingered the culprit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lewis Johnston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 131
