My laptop won't turn on
When I press the power button the keyboard lights up in a split second then turn off again, I already done troubleshooting like draining the power(removing RTC battery, Main battery) and holding power button in 10 minutes. I already have switch the RAM locations. Please help me ๐ฅฒ
See the video below:
์ข์ ์ง๋ฌธ ์ ๋๊น?
0
Hi @eugeneeridao
Does the laptop indicate that the battery is charging when you just connect the charger to the laptop and don't try to turn on the laptop?
jayeff ์
Yes, the charging indicator lights up, but when I pressed the power button it turned off then the same thing happens again.
eugene eridao ์
@eugeneeridao
What colour is the charge light and if it is amber is it steady or blinking?
jayeff ์
It's a steady red. I had an update; it miraculously booted, but I did something. I tried to heat it up using a hair dryer, then it booted. After that, I shut it down, and the problem came back again.
eugene eridao ์
@eugeneeridao
Try leaving it on charge until it indicates that it is fully charged i.e. charge light = white, before trying to turn it on.
If it never turns to white I think that there's a problem either with the battery or the power supply circuit on the motherboard
jayeff ์
๋๊ธ 5๊ฐ ๋๋ณด๊ธฐ
