2012 Door window dont work
2012 ford expedition door window repair
Update (03/17/24)
2012 ford expeditiondoor window its stuock
좋은 질문입니까?
좋은 질문입니까?
Have you checked the fusebox for broken fuses or breaks in cables related to the window? Anything blocking it from moving? A broken hoist mechanism for the window inside the door can also give these problems.
이 답변이 도움이 되었나요?
Most likely a broke window regulator motor those go bad causing the window to be stuck
이 답변이 도움이 되었나요?
Problems with the automatic transmission
when it is hot it disconnects and does not work properly
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 67
