주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2376 질문 전체 보기
How to disable the front camera?
Hi,
I managed to save the iPhone 4 of my friend who remained under a tap running for over an hour. The motherboard works, it's incredible that is, elements that do not work are:
- LCD (dead) (repairable)
- Proximity sensor (repairable)
- Front camera (irreparable)
The front camera is most affected by water damage. The connector of the front camera of the motherboard died.
I tested with another front camera, but to no avail. The camera still does not work.
In addition, when we switch camera (from the back to the front) there is no possibility to return back to the rear camera. The shutter is closed and the switch button is not visible. What prevents them from using the back camera. If he wants to use the back camera, he is obliged to restore the phone so the rear camera is opened at the opening of camera.app on first use.
So I wonder if there was a way to disable the switch of the camera front, with the jailbreak or an application or a restriction.
Thank you in advance for your help.
carlitostyle
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
http://www.youtube.com/watch?v=5Uhe1o9tJ...
There's the video on how to disable your front-facing-camera. This will help you to never "accidentally" flip the broken front-facing-camera on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Sorry for the response time. Thank you very much your solution with iFile works perfectly! THANK YOU FOR YOU HELP!
댓글 달기
가장 유용한 답변
Try this:
Closing the Camera.app by pressing the home button.
Next, open the app switcher (multitasking pane) by double clicking the home button.
Press and hold the Camera icon until it starts to jiggle about.
Tap the little red circle that appears on the now jiggling icon to actually close the app.
Now reboot the iPhone (press and hold home+sleep buttons) and ignore the slider that appears.
After the reboot try to open the camera again. And tell your friend to get used to not using the frontal camera and to ignore the switcher button.
The phone does not need to be restored every time.
Question: Is the phone jailbroken?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Ok i will try by an hard reset. No the iPhone isn't jailbroken. I tell you something when i try this method.
Hi,
I tried with an hard reset but it dosen't work. I told him to not open the camera.app, he understand. Or maybe we can try with an application who only use the rear camera.
Thank you for your help.
댓글 달기
You can return to the rear camera by disabling the camera app
Go into settings, general, enable restrictions , disable camera , this will disable FaceTime also. Exit settings and go back into restrictions, enable the camera . Go back to spring board and open camera, you will see it defaults back to the rear camera. At the moment the only real way to disable the front camera is via ifile and modifying the app txt file. This is only for jail break devices, but for now if you accidentally flip the camera you can get the rear camera via the restrictions app
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First, select the Apps icon on the Home screen, then open Settings app.
Next, just tap on Display.
Choose Full-screen apps.
Lastly, enable Hide front camera.
you can also check best camera android app how to run in pc https://www.checkforpc.com/camerafi-for-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
carlitostyle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 22,717
