Understanding SMC Panic Assertion Failed codes
Hello!
I'm not sure what error code I'm getting, it shows as follows:
ASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x40000000
My understanding is:
0x40000 is the charger port flex
0x400000 is the wireless charging flex
But I'm getting 0x40000000. What's this? I can't seem to find it anywhere else.
Update (04/01/24)
Bump. The phone's stuck in a reboot loop and every loop generates this panic. Any help appreciated, at this point just trying to keep the phone on long enough to back up the data.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
@flannelist you are the Guru on this stuff. You got anything up your sleeve to help the OP with this?
의
This one might need some math. Could be related to multiple parts, @petitepata72947 what preceded the boot loop? Is it damaged in any way?
의
No damage that I can tell in any way, no.
Preceding the loop, it took a full charge, and the next day as the battery was getting low (but not yet sub 20%) it turned off. When it turned back on, it displayed the unable to verify genuine battery message, 0% battery, and would no longer charge.
When plugged in or in wireless charging, it vibrates but does not display the charging.
의
댓글 달기
