주요 콘텐츠로 건너뛰기
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
321 질문 전체 보기
Lower screen displays for a while, but then the image becomes glitched
I have a DS Lite where the bottom screen works for a while, but then it becomes glitched out and discolored. Touchscreen works fine. Sign of a bad connection or a bad screen as a whole?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi! Looks like your lower screen need to be replaced. Do you have a video where you can show how the glitch look like?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It seems you're experiencing an issue with your Nintendo DS Lite's lower screen. Let's troubleshoot this glitchy display! While I'm not a certified technician, I can offer some insights based on common problems:
1. **Bad Connection**:
- A **loose or faulty connection** between the screen and the motherboard could cause display issues.
- Check if the **ribbon cable** connecting the lower screen is securely attached. Ensure it's in a straight line and properly seated.
- If you've recently replaced any parts, consider trying the **old bottom screen** to see if the issue persists.
2. **Faulty LCD Screen**:
- The **discolored and glitched display** might indicate a problem with the **LCD screen** itself.
- Sometimes, a **defective new screen** can cause issues. If you have the old screen, test it to rule out this possibility.
- If the problem persists, consider replacing the **bottom LCD screen**.
Remember that these are general suggestions, and for a precise diagnosis, it's best to consult a professional technician or refer to official repair guides.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cych 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 43
