주요 콘텐츠로 건너뛰기
iMac Pro는 Apple의 지금까지 가장 강력한 iMac입니다. 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core 또는 2.3 GHz 18 core Xeon W 프로세서와 함께 제공됩니다. EMC 3144 / A1862 (ID iMacPro1,1)
iMac Pro / Motherboard dead / No leds on
Hi everyone, I have an issue with my imac pro. It doesn't start anymore.
I have no leds light on motherboard. I already changed power supply but same thing. Thank you for your help.
Regards
Update (04/19/24)
Mise à jour...
Je me suis rendu compte qu'il y avait un bouton sous les leds sur lequel il faut appuyer pour avoir l'état.
Seul la première led s'allume. J'ai également essayé de me connecter en DFU et j'y arrive par contre j'ai une erreur quand j'essaie de restaurer.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 8개:
I have the same issue. Power supply is good, power does come in to the power supply but the LEDS are out.
Under and to the right of the leds is a push button. The leds will not enable unless this button is pressed.
Spanish:
Yo estoy en la misma situación, si alguien puede facilitarme el esquema de conexionado y de tensiones se lo agradecería.
English:
I'm in the same situation, if someone can provide me with the connection and tension scheme I would appreciate it
We have limited information on the iMac Pro system. Here’s a deeper view internally iMac Pro Teardown.
Sadly I never was able to locate schematics and board view drawings for this system. With the logic board number (820-00967) you might google it to see if your luck is any better than I had. I was only able to find this 820-0067 Component Identify thread which offers a link to the schematic but it’s damaged.
I would start off making sure the power cord and power supply are good. As most of the failures are due to power surges or lightning strikes. There are a few onboard diagnostic LED’s you do need to press the small orange button just below the five LED’s.
댓글 3개 더보기
댓글 달기
답변 1개
I would check the AC socket as well as manually short the power button line to see if the button has failed as well as check the power rails.
It’s also likely you have a short within the logic board logic. You need the schematics and board views to work this out.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@danj exactamente estoy buscando donde repararlo no me importa pagar por la información.
Exactly, I'm looking for where to repair it I don't mind paying for the information.
@antoniofer31583 - Ideally, you want to find a local shop, you may no choice other than Apple.
Lo ideal es que busques una tienda local, y puede que no tengas otra opción que Apple.
댓글 달기
답변을 추가하세요
Olivier Paulart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 358
