주요 콘텐츠로 건너뛰기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Ipad air 2 weird charging issue
My mothers ipad air 2 stopped charging. Being 10 years old I bought the battery kit from ifixit and replaced it. Then it would charge but not if the battery got below 24%. It has to be forced into restore mode by holding home and power buttons. I found out she had been using off brand charge cable so that suggested bad tristar. So I bought a few of those and replaced it. The problems persist. The battery drops like a rock (10% every 15 minutes or so). Will not charge below 24% battery without restore mode. Only seems to charge after that if the tablet is off.
Has anyone had these issues? Could it be a faulty battery or PMIC? Im starting to worry its gonna burn her house down.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
check for loose coils around the pmic
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Thank you for the help, I'll tear it back open this weekend and check that. I find the situation with this ipad very suspicious. This thing now has "stipulations" about charging. Changing the tristar did gain one thing, the ipad will now charge above 79%. It wouldn't be so bad if the battery would last like its supposed to.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Finally had time to get back to this. I cannot find any physical problems with the board anywhere. Caps, coils, battery connection...it all looks good and in place. Any other suggestions based on the symptoms? thx
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
idodgeads 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 79
