My purifer unable to fill water in its tank?...why?
좋은 질문 입니까?
좋은 질문 입니까?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 39
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. 기존 질문에 이미지 추가하기
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
oldturkey03 의
