주요 콘텐츠로 건너뛰기
The Acer Chromebook 14 is a Chromebook with a 14" display, released from Acer in 2016. Model Number: CB3-431.
13 질문 전체 보기
It keeps turning off and on by itself.
Hello, for some reasons my acer chromebook keeps turning off and on, thought it was the battery, plugged in the charger it still did the same thing.
I went on youtube, saw a video with similar problem, his solutions were:
Tightening the screws.
Did that worked for some weeks then it started again.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 15개
@maxwellimoh tighten what screws :-) ?
@oldturkey03 All and any screw you see in and out of the chromebook.
@maxwellimoh that sounds like an interesting fix ;-) Tell us how it "keeps turning off and on" exactly. What does it do? What does your Power LED show?
@oldturkey03 Whenever I turn it on, sometimes before I type in my password or even begin anything it turns off.
After it turns off, if I close the lead, few seconds or minutes later it turns back on, then later it turns back off.
My Power Led: At first I thought it was the battery but when I plugged in my charger it was charging normal.
But if I turn it ON even with the charger plugged in, it does the same it.
N.B this occured for complete two weeks untill I decided to disconnect the battery.
I JUST REMEMBERED:
I powerwashed my chromebook more than two times because of the issue.
@maxwellimoh for now I am not quite convinced that this is a power off situation. Start it up and try to run it through the startup. Once it turns off, darken the room and get a flashlight. Now shine the flashlight at an angle against the screen. See if you can still make out the desktop etc.
댓글 10개 더보기
댓글 달기
답변 2개
선택된 해법
After 3 months, I later discovered what was making it to turn off and on.
I realised it was the keyboard.
HOW?
I unscrewed the back, disconnected the track pad, it was still turning OFF and ON.
I connected the track pad back and disconnected the keyboard, that's when it stopped turning OFF and ON.
I already ordered a new keyboard but for now I am using an external keyboard till the new replacement arrives.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Seems like a power button issue that is being pressed at random. It is probably the chassis (did you ever drop it) pushing up against it, by tightening the screws it probably helped a bit by relieving the pressure on the power button. Can you check to see how the power button is (and if its damaged at all).
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
No, I didn't drop it anywhere and my power button is okay. I have solved it, I want drop the answer now.
Sorry, you were kinda right.
댓글 달기
답변을 추가하세요
Maxwell Imoh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 255
