주요 콘텐츠로 건너뛰기
1.83 GHz Core Duo 또는 1.83, 2, 또는 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 질문 전체 보기
My iMac backlight went out what would fix it?
hi, i have an intel imac 17"
Hardware Overview:
Model Name: iMac
Model Identifier: iMac5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: IM51.0090.B03
SMC Version: 1.8f2
a week ago my backlight went out. i can still see screen on lcd if i shine flashlight. it had two pink vertical lines about an inch apart on the lcd for a while.. the dvi out works fines. when i power on the imac the screen lights up like normal for a split second. has anyone else had this issue or know a solution?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
so i replace inverter, and now have working backlight again. but is there a way to fix lines on lcd? ill take a pic and add it. theres one on each side of big white line. i can live with the little lines but the big white on drives me crazy.
댓글 달기
답변 1개
선택된 답변
Usually if you can see the desktop the problem is with the inverter. I would check the cable connections and replace the inverter first as it's much cheaper than the LCD.
Apple iMac "Core 2 Duo" 2.0 17-Inch Specs
Identifiers: Late 2006 - MA590LL - iMac5,1 - A1208 - 2114
Here's the part: iMac G5 17" 1.9 GHz EMC 2104 and Intel 17" EMC 2114 Inverter
iMac G5 17" 1.9 GHz EMC 2104 and Intel 17" EMC 2114 Inverter 이미지
상품
$89.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
all connections and stuff are good.ordered inverter off ebay so should be able to try that tomorrow. if its not inverter what else could it be? is it safe to test bulbs on another inverter if inverter doesnt fix? and if it were found to be bad bulbs is there a good general guide to replacing? also any ideas about pink line? possible dead pixels? thanks again mayer
Replacing the bulbs in an LCD is not for the faint of heart or novice. I can get you to the guides but lets wait till you've tried the inverter and your results before going there.
added to question
댓글 달기
귀하의 답변을 추가하세요
Taylor wittman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,355
