My left click becomes double-clicking
Every time that I click, it becomes double click
좋은 질문입니까?
좋은 질문입니까?
Just pressing the button once producing a second click is what I am assuming you have entered. I have had that happen on my own logitech mice after a while, and it was the mechanical button inside the mouse wearing out (there is a tiny spring which weakened, and allowed the inner switch part to bounce during the movement.
Assuming it is on a PC, check the mouse isn't programmed to doubleclick (it might be a setting). You could also try adjusting the double click rate which might help not have it detect it.
If it is the button, opening it up and replacing it (which would need soldering skills) would work. The button likely has a part number on it, and likely could find it at a place like Digikey.
이 답변이 도움이 되었나요?
Hey Mate, if you left click on your computer does it have the same problem?
If if is a pc, try hooking up a different mouse. This will isolate the keyboard and the mouse. If the control key gets busted and tells the computer that control is being held down, the clicking can go haywire.
So let us know the result of trying on the trackpad/different mouse.
Cheers
Falcon16
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 8
지난 30일: 84
전체 시간: 1,064
댓글 1개
Dose this happen when you click your left click more then once?
Braiden Hill 의
