주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
MacBook doesn’t charge
The MacBook doesn’t have any sign of accepting charge from the original charger (80w). When I plugged it in to a different charger (60w) it said it was charging but then in the morning it was still dead. It’s charged off a 20w charger before and I also tried the only other charger that’s USbc that I have which is a 30w charger
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Did you try a second USB-C cable? Make sure it’s designed to charge as some don’t work fully.
Give the systems age you may need a new battery and/or the systems charging logic needs repairs.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
All of the chargers were used with a different cable and they were all charging cables
@sambaumann - I’m assuming you also tried the other ports just in case one side wasn’t working. At this point you have a logic board issue within the charging logic.
There are techs with deep micro electronics skills who can fix your logic board otherwise it’s replacing it which can get expensive depending on the config.
Where do you live? Country and nearest large city, maybe we can aim you to someone to help you.
I checked the price of logic boards and the price of repairing them and I think it would be better just to get a new Mac as the one I have is extremely old and will probably make me end up spending more money repairing it than if I just bought a new one
댓글 달기
답변을 추가하세요
Sam Baumann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 138
