주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
20 질문 전체 보기
Mac Mini Late 2012 bank 2 RAM slot went bad randomly
I recently purchased a Late 2012 Mac Mini from ebay. It came with 4gb ram and no hard drive. I put in an SSD and put in 8gb ram (2x4gb). It booted fine and I installed catalina onto it unti I shut it off after about 2 hours of use and now whenever I turn it on it with a stick in bank 2 it gives me the three beeps. I've tried different RAM DIMM's but to no avail. the socket looks ok. I was careful during the drive install. Device booted fine proabably 2-3 times before this became an issue. Logic board failure? Any answers would be appreciated. In the meantime device works fine with 1x4gb stick in the top slot (I am writing this on the Mac Mini) but it would be nice to get my 8gb back. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
You know you can install a single 8GB SO-DIMM. I have the exact same system which I installed Two 8GB to get 16GB but one will also work!
Repairing the RAM carrier frame will likely require replacement which could end up leaving you with a bigger mess. I would just use a bigger SO-DIMM and call it a day.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Update: I actually got the slot to work again after just pressing down on the right side with my finger as the power button was pressed. Device booted and now shows 8gb!!!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Grant 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 4
전체 시간: 78
