주요 콘텐츠로 건너뛰기
Valve Steam Controller, released November 10th 2015. Model 1001.
Back R5 Button not consistently working
Hello Guys,
Has anyone be lucky with fixing the back R5 (or L5) Button ?
Basically, the button 16 does not consistently work:
I have opened up the controller, and it is still not working consistently when I directly press the button. I must click off the center to get it to work every time.
I am quite surprised as I barely use the controller. I hope it would be just dust, but it seems more serious.
Any leads or ideas please ?
Thanks :D
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If you are pressing the switch directly and it fails to read the most likely cause is mechanical failure and a new switch will need to be soldered or swapped put I honestly forget I'd the left and right triggers on the steam controllers are modular or soldered driectly to the boars. But once the contact plates inside a switch wear out there isn't much you can do.
I'd try some isopropyl alcohol, de-oxit or bw-100 to see if the trigger starts working magically after being cleaned out property
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I was not clear enough. The switch kind of works when I directly press it.
We can clearly see on the switch where the black backplate button is hitting. Using a toothpick, if I press at the same spot, it is not working unless I press hard. But I press slightly off center, it is working constantly.
I am not familiar so much with PCB & switches. Would it be wise to disassemble (get rid of the "tape") the switch to clean it with isopropyl alcohol ?
Yeah isopropyl alcohol it generally safe for electronics expect for screens.
댓글 달기
답변을 추가하세요
Haeding432 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 126
