Why is my black ink not working?
Every time I print a document, the black ink is not working even though it has an ink inside the cartridge
좋은 질문입니까?
좋은 질문입니까?
Hi,
Have you check the ink is able to flow from the cartridge or the container to the printhead ?
If not you're printhead is clogged.
BR
Artefil
이 답변이 도움이 되었나요?
hi just go to menu settings deep cleaning press (menu + mono +menu) then press upward 7 and 6 and then press upward select black.
이 답변이 도움이 되었나요?
Go to the menu and maintenance and you will find a option for cleaning select black and use the strongest setting the printer will clean the ink head for you and it should work greatly after that
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 13
지난 30일: 36
전체 시간: 610
