Why can't my computer turn on
Maybe someone wants to help me, my computer usually turns on normally, but suddenly it's hard to turn it on, the on/off button doesn't seem to work, but once it does, it only turns on for about 0.5 seconds and then turns off again, and that's the cycle
좋은 질문 입니까?
댓글 4개
Hi @bagusaditiya
What is the make and model number of the PC or motherboard if it is a custom build?
jayeff 의
Hi @jayeff thanks for asking, motherboard MSI B450-A Pro max (AMD)
Bagus Aditiya 의
Hi @bagusaditiya
If you have a DMM (digital multimeter) check if the PSU a). turns on and b). that all the voltage supply values are correct.
Use the paperclip test to check if the PSU turns on (and stays on) and also that all the voltages are OK.
jayeff 의
@jayeff I've tried it, and it works, so what do you think could be the problem?
Bagus Aditiya 의
