Double blinking light and flickering problem
Hi guys,
I’ve seen this problem posted a few times and I’ve done my best to troubleshoot the situation but to no avail. This is a bit out of my element but I unfortunately economically unable to purchase a new one after a recent move so I am doing everything I can in hopes of reviving my tv.
Upon plugging in my tv, it is in an endless cycle where the red light will flicker twice, attempt to turn on and shuts off completely and continuously does this. During the flickering, when I unplug main board from the power board, the back does stay lit and does not flicker off.
I tried replacing both the main and power boards, as after researching the issue these were the most common issues. Replacing both of these didn’t do the trick and I am now at a loss for what could be the next move.
Any help or direction with next steps would be greatly appreciated! If there’s any information I can provide that would be of assistance please let me know as well. I will attach photos below.
Huge thank you to any input!
좋은 질문입니까?
I actually have a very similar issue, although I haven't replaced anything yet. When I unplug the main board from power the relay stops tripping. So I reconnected power, and I unplugged, both LCD driver ribbon cables, tv powers on and I get the all things good UI noises. Plug in one cable, good noises. Plug in both cables, endless power cycling.
I suspect that means my panel is bad and it's straight to the recycling for this display. Does that sound accurate to everyone?
Vince 의 공유
@vincenzolagorio Did you ever figure out a fix for this? Seems we had the same issue
Racook999 의 공유
