My Playstation 3 is automatically turn off
Hi
My Playstation 3 automatically turn off after i start it takes just 2 to 5 seconds can you help me what kind of this issue please
좋은 질문 입니까?
Hi
좋은 질문 입니까?
Hi!
First of all,
Did you tried another power cord and wall outlet? Also tried another hardddrive?
Most of the time caused by the power supply or the CPU/GPU.
First I would try to replace the power supply and see if that will fix it!
If not, you probably need to reball the CPU/GPU.
Guide how to replace the power supply: PlayStation 3 Slim Power Supply Replacement
Please let us know how it goes and good luck!
해당 답변은 도움이 되었습니까?
It sounds like your PlayStation 3 may be experiencing a hardware or power-related issue that is causing it to shut off shortly after starting up. Here are a few potential causes and solutions to consider:
1. Overheating: One common reason for sudden shutdowns is overheating. Make sure your PS3 is placed in a well-ventilated area with plenty of airflow around it. Check the vents for dust and debris that may be obstructing proper ventilation, and clean them if necessary.
2. Power supply: Another possibility is a faulty power supply unit. Try plugging your PS3 into a different power outlet or using a different power cable to see if the issue persists. If the problem continues, you may need to have the power supply unit checked or replaced.
3. Hardware malfunction: There could be a hardware malfunction, such as a defective component or connection inside the console. In this case, it may be best to have a professional technician inspect and diagnose the issue to determine the specific cause and necessary repairs.
4. Software issue: Occasionally, software glitches or corrupted data can cause unexpected shutdowns. Try booting your PS3 into safe mode and performing a system update or restoring the system to default settings to see if that resolves the problem.
If none of these suggestions resolve the issue and your PlayStation 3 continues to shut off after a few seconds, it is recommended to contact Sony customer support or bring your console to a certified repair center for further diagnosis and repairs.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 16
