2012 A1278 Screen Display Burn GPU Fix?
So, I have just bought an old 2012 A1278 2.5 Ghz model for just a few cents.... literally! The previous owner sold it as defective (No display only a white screen with a brown burn like design). 1st thing I did was turn it on to see if it boots up, everything fine except the display issue. I have connected up a BRAND NEW LCD and I get to be able to read the log in screen! But what a mess it is..... I guess @danj or @oldturkey03 will confirm that the GPU is burned out and hence I have a nice complete set of doner parts from this machine! But, IF there is a fix possible I would love to know!
Image 1 is from the new display (No bezel fitted)
Image 2 is from another display (Note that at the side of the unit is the new display without the bezel fitted)
좋은 질문 입니까?
@livfe so the images you posted, are from displays that show like that on your "new" purchase. Those same displays show proper on another computer? Have you taken your new purchase apart yet, or at least opened it, to see what's going on in the inside?
oldturkey03 의
@oldturkey03 Yes I have opened up the unit to install the 'new display'. I I have added fresh images from the new and another display.
livfe 의
@livfe would you mind very much to post some large, well focused images ( both sides ) of the logic board from this computer?
The same display shows perfect on another computer?
oldturkey03 의
@oldturkey03 I haven't tried the 'New' Display on another unit as yet, not very enthusiastic to open up a perfect unit that is for sale in case I somehow with my great luck waste that also...... I can try to put up some clear images in the next 1-2 hours....
livfe 의
@livfe that's fine. No worries. After all, it is possible that you have two bad displays :-)
oldturkey03 의
댓글 9개 더보기
