주요 콘텐츠로 건너뛰기
Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
20 질문 전체 보기
Bluetooth bad connection! Even when replaced
I had re-shelled my switch using a ExtremeRate shell but now my bluetooth connection doesn't work properly.
I can sometimes get one controller to pair ok for a couple of minutes but never two. I replaced the bluetooth module. Any clue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi CardCraft!
Did you replaced the IC on the motherboard or the antenna’s?
If you’ve replaced the IC, then the next thing to do is to replace the antenna’s. It does sound like the antenna’s are the issue here, as it does connect sometimes!
Also check if the antenna’s are connected properly, and check for damage…
Also, keep in mind that 3rd party shells can give issues like not perfectly seamless/aligned as the original ones (still the ExtremeRate shells are good shells for replacement, always check if the parts will fit in the shell seamless).
Good luck with the repair!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Cardcraft 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 84
