okay guys, listen up. yes ive been thinking about this problem since i posted this six hours ago.
btw brother, read this only if replacing the batteries didnt work for you. ive explained the correct way to place them on my 2nd point
anw, what did i do?
1) i kinda forcefully pulled out the film box behind. it was jammed pretty badly and it was almost impossible to pull out the film box. the first protective layer was barely out of the film box yes. just try to get a hold on the two holes on the film box and get the lower part of the film box out just a little bit, then wiggle it left and right while still pulling it out gently. DO THIS ONLY AND ONLY IF REPLACING THE BATTERIES DIDNT WORK FOR YOU.
2) and as for the reason why my camera lights blinking died, my dum ahh placed the batteries wrong.
inner most battery should be placed +ve bottom -ve top
outer most battery should be placed +ve top -ve bottom
$@$* fixed itself after i did these tho i am yet to try out the camera again.
thank you for coming to my ted talk. may those who still use this camera in 2024 find peace and happiness.
댓글 1개
man... is anyone even out there anymore...
yoku oboenai 의
