주요 콘텐츠로 건너뛰기
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
SELECT button is triggered by pushing down on the lower baseplate
I just recently got out my 3DS that I haven't used in years and decided to mod it. After using it for a while I noticed that during gameplay the pause menu in some games would come up randomly.
During some troubleshooting I found out that pressing down on any part of the lower baseplate of the 3DS causes the SELECT button to be triggered and the closer you get to the right side of the 3DS (where the SELECT button is) the easier it is to unintentionally trigger it. Also, the physical button is not moving just to inform you.
I originally intended to disassemble the 3DS to just clean it but now it seems I might have to do some investigating as well.
Posting this here as a precaution to see if anyone know what is causing this before opening the 3DS up myself.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Ronan!
Maybe there is some dust there! Best thing to is to disassemble it and clean it there.
If cleaning isn't working, then it's probably for the best to replace the part.
Luckily those buttons are located at the power board! Replacing the power board is easy.
Guide: Nintendo 3DS 2015 C-Stick Replacement
Good luck with the repair and please let us know how it goes!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ronan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 120
