Does it turn on immediately after you have switched it off or some time later?
If later, does it always turn on at the same time?
Try blocking the IR window on the right hand side of the bezel below the screen and check if it turns on by itself again.
Also temporarily remove the batteries from the remote control unit and check if it turns on
Try a power reset and check. Disconnect the power to the TV and then press and hold the TV power on button for 30 seconds and then release it. I'm not sure if you then have to set it up again or not e.g. rescan for channels etc
Hi @danielflor78486
What is the model number of the TV?
Have you checked if there are any "timer" settings activated in the TV menus (that is if it has any such setting)?
jayeff 의
Model is 32MD350B/F7
No time settings are on.
Thank you!
Daniel Flores 의
@danielflor78486
Just trying to eliminate possibilities
jayeff 의
