주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 Nintendo DS Lite는 2006년에 Nintendo DS의 후속작으로 출시되었습니다. 이 기기의 내부에 진입하는 방법은 간단하여 손쉽게 수리할 수 있습니다.
Why does my DS not turn on
Plugging in the DS shows a solid charging light but no red or green light and will not turn on. The battery is working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Ayden!
Most of the time a fuse on the motherboard went down. Please test F1 and F2 on the motherboard with a continuity test. If one of them failed, please replace it. You can also replace the whole motherboard but this would be expensive.
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I have red light and charging, trying to turn on get nothing no green light, battery checked worked fine in another device, F1,F2 and EM10 getting correct reading, so what else could it be? This classed as motherboard totally failed as don't want to waste my time on it if so?
If you did tried another battery, it's most of the time motherboard related. As you checked the fuses and the EM10, you can replace the motherboard. It's more expensive but will save you some headache and testing!
댓글 달기
답변을 추가하세요
Ayden Guzman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 30
전체 시간: 176
