주요 콘텐츠로 건너뛰기
The Sharp AQUOS LC-32LE185I is a TV with a 32-inch screen. This TV has an HD Ready resolution of 1366 x 768 pixels.
6 질문 전체 보기
Why is my television is Not powering on?
Whenever I start my TV the back light is on but my television is Not starting then I saw a video on yt to solve this problem. Then I go to the reset Button on television And hold it for 10 second And the television is started but after few seconds the television is automatically into black screen but back light is on
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
That's frustrating! Let's troubleshoot:
1. Power cord: Ensure it's securely plugged into both the TV and the wall outlet.
2. Outlet: Try plugging another device into the outlet to rule out any issues.
3. Power button: Ensure it's functioning correctly (try using the remote or a different power button if available).
4. Surge protector: If using one, try plugging the TV directly into the wall outlet.
5. Circuit breaker: Check if the breaker has tripped or the fuse has blown.
6. TV's power settings: Ensure it's not set to "sleep" or "energy-saving" mode.
7. Unplug and plug back in: Sometimes, a simple power cycle can resolve the issue.
8. Check for loose connections: Verify all internal components (like the T-Con board) are securely connected.
9. Faulty power supply: If none of the above works, the power supply unit might be faulty (consider professional assistance).
If none of these steps work, it might be a more serious issue requiring professional repair or replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anirudh parihar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 25
전체 시간: 25
