주요 콘텐츠로 건너뛰기
he Xiaomi Redmi 8 is a low-budget smartphone by Xiaomi released October 2019. It has a 6.22" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Snapdragon 439.
33 질문 전체 보기
My front screen came out somehow it vibrating but screen not respondin
My front screen came out due to losses of gum and one day somehow my phone screen became black and not responding screen but it play alarm and vibrating when I put for charging and try finger print it to open
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Adithya, given that everything else seems to be working, it's fairly safe to say your screen has failed and needs to be replaced. On your phone that means opening up the phone, removing all of the interior components and transferring them to a new screen plus frame assembly. Sorry to say that iFixit doesn't have a guide showing you how to do that repair, but the French site SOSav has exactly what you need.
Xiaomi Redmi 8 Screen Repair - Free Guide - SOSav.fr
The guide is written in French, of course, but used with the Chrome browser's translation feature, it's quite usable and very well written. As far as finding a replacement screen, it seems to be readily available and very inexpensive. You can start with the big sites like Amazon, eBay and AliExpress; depending on your location there are almost certainly other sites where you can get the part. Here's one from AliExpress that looks like it would work.
Choice For Xiaomi Redmi 8 LCD M1908C3KG Touch Screen Digitizer Replacement For Redmi 8A Screen MZB8458IN M1908C3IC LCD Parts - AliExpress 509
Note that it comes with or without a frame; the guide I suggested is for a screen with the frame already attached. You can save a couple of dollars buying it without the frame, but be aware that the replacement procedure is completely different and would require a separate guide that I wasn't able to locate. You can probably find one on YouTube if you care to look. Replacing the screen and the frame together is the recommended procedure, as the screen comes already bonded to the frame so you don't have to worry about gluing it on and/or making it water tight.
Good luck and let us know how it all turns out!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
418 Adithya Mesta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 9
