How to fix square button?
The square button when pressed is stuck and feels awkward. Feels like a controller with a sticky button. I tried alcohol and blowing it. need Help!
좋은 질문 입니까?
좋은 질문 입니까?
You can find a repair part to fix the PS Vita square,cross,round, triangle, start or select button here :
http://www.consolereparatie.eu/contents/...
Verry easy to fix it yourself, you can use the PS Vita teardown guide found on here :
해당 답변은 도움이 되었습니까?
i can only suggest calling sony it is still in warrenty and this issue will be covered because its not your fault. you can take it apart but there arent many spare parts knocking around so i would just call them they should replace it
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,750
댓글 2개
has anything been spilt down it or is it the mechanics of the button?
daniel robinson 의
@ daniel robinson It is the mechanics of the button
joseph floyd 의
