주요 콘텐츠로 건너뛰기
2019년 9월 25일에 출시된 7세대 iPad는 32 또는 128GB 모델로 제공됩니다. 모델 번호 A2197.
20 질문 전체 보기
¿Why my ipad7 is not turning on?
I come here searching for information and help to repair my wife's IPAD 7 WIFI-2019, model A2197. Iam not expert in phone repair, but i want to learn, so i am reading and searching information.
I sent the ipad to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
This is what i found until this moment:
1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
2) no short circuit in lines VCC_MAIN, VCC_BATT.
3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
4) the current draw from the power supply, without battery, is about 26mA from the charging port.
5) i haven't the diode mesurements of the main lines if power, so i dont known if i have a fuge in VCC_main or other line of principal power.
6) i dont know what other test or action i have to do to diagnostic the fault.
I'll appreciate so much your help.
God bless you, and thanks for this forum.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Try to go to a store and test a new display,maybe your screen is broken when you repairing and it not turn on
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 12
전체 시간: 69
