주요 콘텐츠로 건너뛰기
2, 2.26, 2.53, 또는 2.66 GHz Core 2 Duo 프로세서
Overheating, fan not spinning. Replace fan?
Mac Mini started turning itself off a few days ago, nothing in the system.log to suggest anything software related, it just completely switched off. Would happen randomly, but seemed to be more frequent when watching a video or stressing the system (I use it as a media center) so I suspected heat issue.
Fan spins randomly, but is usually not on as far as I can tell. When it does spin it makes some bad noises. Tried SMC Fan Control to set the fan speed but it just says 000rpm and does not respond to anything. Watching 1080p YouTube videos does not cause the fan to turn on.
Just wanted to make sure it's likely the fan itself that needs to be replaced, and not something else. I suspect the weird fan noises are a giveaway that it's the fan hardware itself and not some kind of controller. Any input appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
If the fan makes a strange noise it's probably catching and not spinning freely on the bearings. You may be able to fix it yourself by cleaning some dust and debris out of your computer and fans, but fans are not expensive if they do require replacement.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Ended up ordering the fan and replacing it, seems to have fixed the problem. Hasn't shut off randomly since the fan being replaced and it actually runs now.
That's great to hear! Congratulations on the self repair.
댓글 달기
Hi,
I want to test my fan on the bench. How to wire just to make it go. I have a working Mac Mini - i5, but looks like something on the mother board gave way. The unit works fine though except for the fan. I just want to wire to stay on full tilt to keep it cool. So far haven’t found the answer to what seems like a simple issue.
thanks in Advance,
Doug
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Derek Rose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 4,216
