주요 콘텐츠로 건너뛰기
The seventh iteration of Apple's iPod Touch, released May 2019. This model comes with up to 256 GB of storage and an A10 processor. Model number A2178.
Why does my iPad not charge or boot?
My iPad has not charged or booted up in over a year. No apple logo,no response to charging, nothing. I don't know if it is obsolete and therefore doesn't work permanently or if there is a fix? Also when it did work the apps one by one stopped working. Let me know your thoughts.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
That’s a long time for the battery to be sitting flat.
The first thing I would recommend you do is check the charging port on the iPad to see if there is any dirt/fluff or anything else that may be interfering with the lighting connector.
If it’s dirty or fouled up in some way lol up how to clean lightning port on YouTube and clean the port.
Next check that your lightning cable & wall plug actually work on another device.
Now that you have completed the steps above, plug cable into port and wait, because a dead flat battery will take a long time to register and show the red battery charging on the screen.
if you have no sign of life after an hour then it is possible that the battery is unable to take and hold enough charge to start the screen. So you will need to look at replacing the battery.
It could end up being uneconomical, (mainly because there’s no guarantee that the new battery will fix the problem), but it’s the only way to verify if the iPad still works or not.
Hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
josiah Jennings 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 110
