주요 콘텐츠로 건너뛰기
Guides and repair information for the Huawei MateBook X Pro, which was released in 2018 by Huawei.
2018 Huawei Matebook 13" MACH-W19 battery replacement.
I bought a tool kit to enable me to replace an aging battery. YT videos indicate that there are additional screws underneath the feet. Rem oving the first one revealed another plastic bump surrounded by what looks like a circlip (???) At which point I began wishing I'd sent the laptop to Huawei for the job.
Any suggestions?
Roy
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I can't find a video of your specific model, but I found one that has a similar model to yours. I would guess that was the video you found and watched yourself, since it shows screws under the feet.
But you don't have the exact same model, based on how close the screw hole on yours is to the foot I would say that it's way closer to the foot on your model.
Since I can't find anything about your exact model, I can't say this for sure. But I would guess that there isn't any screw below the feet of your laptop, this is solely based on how close the screw is to the middle of the foot.
I would start with removing all visible screws, then gently try to insert the thin blue opening pics between the two sides of the laptop in order to open up the clips still holding the parts together even though the screws are removed.
Since there could be missed screws, just be careful in case you feel any resistance when trying to separate the halves, especially around where the feet are placed.
Hope this was helpful! :D
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks. You could well be right but the inner part of the feet is obviously designed with something in mind. I did try opening the case but in all honesty it makes me very very nervous. Are the multiple "guitar picks" included in the kit what you suggest for opening the case - by inserting them progressively around the circumference? Anyway I'll try again tomorrow. But on balance I'll probably write off the cost of the kit (I bought the most comprehensive and expensive one....)
I can tell you that the clips on this shell are VERY strong, but as the first comment said, you should still be careful to make sure you aren't forcing any hidden screws. I would start by using the pick up by where the frame connects by the hinge with the pick and slowly work your way around. If you come across an area that doesn't separate as easily as other areas, pause and try to find any hidden screws. You should eventually be able to release it all the way around.
댓글 달기
답변을 추가하세요
Roy horologic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 114
전체 시간: 1,524
