주요 콘텐츠로 건너뛰기
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How repairable is the hardware microphone mute button?
The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece. I'd rather avoid replacing the whole headset due to the price.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Somone said they used wd-40 contact electric spray on it and that solved it, others say you keep pressing and unpressimg the mute button, if you still have warranty contact manufacturer.
If you're a tinkerer you can disassemble the headset and clean the mute button from the inside, if that doesn't solve it then I would put a small solder point on its tip from the inside and keep it unmuted all the time and not play with it, maybe use software matting instead after.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Corey Sutlief 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 71
지난 30일: 333
전체 시간: 1,484
