주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 2월 25일에 출시된 Valve에서 만든 휴대용 게임기, LCD 디스플레이가 장착된 Steam Deck의 수리, 분해 및 문제해결 정보입니다. 모델 번호 1010으로 식별됩니다.
Replacement LCD backlight on no image
I recently received my replacement screen installed it, but for whatever reason, the steam deck turns on, and I could clearly see the back light on, but there is no image. Touchscreen is functioning, I dock it and it works. It just won’t show the image in handheld.
I already tried to hold the power button down for 20 seconds no luck I held the power button and the volume button and still no image. took it apart and put it back together still didn’t help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Your best bet here is to double-check the display's ZIF connectors. It is all too easy to get those flat ribbon cables in slightly cockeyed to where they make contact on part of the connectors but not all of them. I'd suggest opening it back up and pulling the motherboard again to get to the plug underneath the motherboard.
You see that white line on the ribbon cable right next to the connector? It should look the same as in this picture; an even distance from the connector all the way across; if it's offset then it's not in right. As long as you're there, open it up and pull the cable, then clean the pins on it with some 90% or higher concentration isopropyl (rubbing) alcohol. Inspect the length of the cable for any signs of damage, including tears or excessive bends that could damage the internal traces.
Once you're happy it's all good, plug it back in, making sure it's fully inserted, then reassemble the motherboard. Now do the same with the other end; inspect, clean and make sure it's inserted fully, the same as it appears in this picture.
If it still doesn't work, unplug the display cable from the LCD and plug it back into your original LCD (don't dismount the new screen from the frame). If it works there then it's almost certainly an issue with the replacement part; otherwise you may have a cable or motherboard issue.
Give this a try and let us know what you find.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Nightmarsh101 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 27
전체 시간: 607
