주요 콘텐츠로 건너뛰기
1.83, 2 또는 2.16 GHz Core Duo 프로세서
281 질문 전체 보기
SSD, either instead of optical drive or as second SATA device
hi there,
my optical drive was not really working from the beginning, so getting rid of it would be a good idea. the optimal solution would be to insert a SSD instead of the dvd-drive.
reading this discussion(SSD instead of optical drive), i'm wondering if the same is valid for my older macbook pro / A1150(2006 model). the hdd is SATA, but according to the system profiler, the MATSHITADVD-R UJ-857 optical drive is an ATA device, so that's a completly different kind of interface.
so i guess the only option for using a SSD would be to replace my current 100GB sata with an sata-SSD. or perhaps there is a second SATA interface onboard?
thx & so long
harri
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
There are optical bay adapters now for using either SATA drives or PATA (ATA, IDE, EIDE) drives in your older MBP or even in PowerBooks. I just put an SATA in a PowerBook this week. I really like the LaCie external optical drives as they are very durable and priced well under an internal drive.
http://www.lacie.com/us/products/range.h...
Do a web sear for "mac & optical bay adapter".
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
THX for your response!
maybe that was a little bit unclear, but i really don't need an optical drive.
do you know how this adapter performs? because it would be nonsense to put an SSD into this adapter to get a performance-benefit, but to introduce a new bottleneck(the ATA-SATA - converter).
any idea if there is a second SATA-controller onboard?
so long,
harri
댓글 달기
귀하의 답변을 추가하세요
hagl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 534
