주요 콘텐츠로 건너뛰기
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
L3 button (sprinting) does not work after change of potentiometer
Hi,
Changed my potentiometer (left joystick) and it works great after the GUI installation. BUT, the toggle on the L3 does not work. I can’t sprint, and I have disassembled the controller 10 times, can’t see anything wrong. I really think I did a great job!
What to do here?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
How do I fix stick drift on my controller
댓글 달기
답변 2개
선택된 해법
Hi!
Are you sure that it makes good contact inside the joystick? Maybe it's not pressing all the way in.
Can you share some pictures with us?
Anyway, if you tried everything and you just won't get it to work, I would just replace the left joystick. Saves you a lot of investigating and headache. And when you are there, maybe easier to replace it for a hall effect joystick?
이 답변이 도움이 되었나요?
점수 3
댓글 15개:
Yeah, I will try to post some pictures here this afternoon.
I’m thinking of byuing the gulikit joystick!? A bit expensive though. Feels like I could have just bought a new controller buy now haha.
Yeah those are great. They are more expensive but it's worth it. I fully understand yes haha. It's probably for the best to replace it tho..
It did not work so it must be the that little solder spot missing the cooper-ring,but we found the issue!
It is the same issue again everything works except Toggle L3 (B10 on gamepad tester).
So how do i find the right traces?
Indeed, the issue is found!
Here you can find some more info about that: https://www.reddit.com/r/soldering/comme...
[image|3429584]
댓글 10개 더보기
댓글 달기
I bought a secondhand controller with the right gen and switched the motherboard to match the controller. Works great!!
I think I &&^&@@ it up doing to much soldering on the solderpoints and ripped the copper ring.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joakim Loso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 32
지난 30일: 143
전체 시간: 1,684
