주요 콘텐츠로 건너뛰기
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 질문 전체 보기
질문 마감됨
Bent the Aluminum case.
So I was demonstrating the ruggedness of my gform extreme sleeve, something I have done at least a hundred times, and bent the back of my third generation iPad. Everything is operating fine, so I assume I just need to replace back and the bezel (which was destroyed when the glass separated from the case).
I assume I am going to have to take this back to Apple and let them fix it, or, more likely, purchase a new one. Either way I want to find a way to purchase a replacement back. If I need to get a new one, then I have a fun project that I can give away when I'm done.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Apple will know that you dropped it if the case is bent. Thankfully, aluminum is a softer metal, you *should* be able to carefully bend/hit it back into shape. Otherwise, I assume you could get a busted iPad from ebay on the cheap.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can buy a shell, or try taking everything out of yours and heating it up and bending it back in place.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,230
